SOLD!!! Mod please remove
I am selling my infra red svt
106000 kms on the car. Car
Contact me via email [email protected] or pm
Car needs an engine or to be rebuilt. Dropped a valve on the number 4 piston and cracked it. I have an entire spare head assembly to replace that but u would have to source either a bottom end or rebuild it.
The car has the following performance parts:
Top speed turbo intake manifold
Cfm 67 mm throttle body
Custom 2.5-3 cold air intake
Obx R header
Dominate engineering high flow cat
2.5 borla cat back exhaust
Mad ignition coil
Massive 8.3 plug wires
Steeda poly passenger mount
Steeda poly drivers mount
Steeda poly dog bone mount
Fidanza light weight flywheel
South bend clutch stage three clutch
Sct x3 tune
Drilled rotors all four
Stainless steel braided front brake lines
The car has the following new ford oem parts installed less than 500kms ago:
2 front lower control arms 1 mm oversized ball joint s
2 front wheel bearing s
2 front sway bar end links
2 front inner and outer tie rods
2 front headlights
2 rear lower control arms
2 rear sway bar end links
2 rear wheel bearing s
All the rear alignment cam bolts and nuts.
All caliper bolts
Emergency brake cables
Speed sensor
Clutch master cylinder
180 degree thermostat
Caliper bolts
Ball joint pinch bolts
Fuel pump
Fuel pump relay
Fuel filter
Oil pan and plug
Window regulator clips.
Car has the following add on s :
17 x 7 with + 45 offset Liquid metal static chrome wheels
Brand new 215 45 17 tires
Altezza 3d taillights
Carbon fiber hood
Powder coated valve cover
Extreme dimensions rs front bumper replica
Tinted rear windows
The interior is factory and is in amazing condition 10/10!
It is inspected and registered till January. It's been garage kept up until this may. It's never been winter driven. It does have some rust beginning to form on one rear quarter from where the fenders were rolled and the paint started to flake and another where the hatch closes. The drivers side window switch stopped working needs a new one.
If I can't get any interest I will most likely part it out.
Car as whole $ 2800 obo
http://s1295.photobucket.com/user/chris_boyd2/media/_20_zps71acc6df.jpg.html?sort=3&o=7
http://s1295.photobucket.com/user/chris_boyd2/media/_202_zpse543ab81.jpg.html?sort=3&o=6
http://s1295.photobucket.com/user/chris_boyd2/media/_203_zps246ec0ef.jpg.html?sort=3&o=5
http://s1295.photobucket.com/user/chris_boyd2/media/_204_zps70f06e16.jpg.html?sort=3&o=4
http://s1295.photobucket.com/user/chris_boyd2/media/_205_zpsf10a9707.jpg.html?sort=3&o=3
http://s1295.photobucket.com/user/chris_boyd2/media/_206_zps7214885e.jpg.html?sort=3&o=2
http://s1295.photobucket.com/user/chris_boyd2/media/_207_zps9ef2d1d9.jpg.html?sort=3&o=1
http://s1295.photobucket.com/user/chris_boyd2/media/_208_zpsb9f166c7.jpg.html?sort=3&o=0
Obx R header
Mad ignition coil
Sct x3 tune
2 front headlights
All caliper bolts
Speed sensor
Caliper bolts
Fuel pump
Fuel pump relay
Fuel filter
Oil pan and plug
Carbon fiber hood
Tinted rear windows
