1 - 20 of 70 Posts
I have read and searched, but no one seemed to have the same scenario as me. I have a 02 focus with a blown sohc. I know the wiring harness needs to be changed along with the ecu/ ignition. I know that my transmission (4f27e) will bolt up to the dohc fine. The only things I need clarification on are the motor mounts and the shafts. Which if any of the motor mounts will I need to change, also it made sense to me that if I'm only changing the engine that the transmission and attached parts would work the same. Could there be any other problems I may have.
The big reason for this project is that I can't afford a nicer car, but a hobby of mine is fixing cars. Also I've had engine troubles in the past with another vehicle and as soon as I heard the sohc had engine problems (valve seat dropping) the engine type sounded like a money pit. Not to mention it's a grand to get a 200k sohc engine from the wreckers were I'm located. Thanks ahead of time for any help. ( I just wanted to be really sure of the project before I invest time and money into it)
/人◕ ‿‿&#65
Change all 3 mounts.
Change the axles.
Use the MTX75.
Make sure you get everything from a 02+ Zetec. Makes the swap easier. This way you don't need to change the dash wiring.
Why do some people say it's as easy as changing the harness and the ecu. I don't want a manual transmission. I'm trying to do this for as cheap as possible so getting all the parts from the front end of a dohc is not an option. I need to know exactly what I'll need. I wish there was a definitive answer no offense to you Kauai Guy, but the forum says certain things and you say different. Makes me weary. Anyway from what I've gathered from the forum and other sources I will need to change the following:
the ecu and harness
the ignition switch to match the ecu with matching chipped key (although I thought chipped keys were optional)
I've read that the 4f27e will bolt up to the dohc engine. why the shafts would need to be different doesn't make much sense. After looking at rockauto.com they have the same shafts and bearings listed for both engines. Also I looked at the only motor mount they sell for both and there's minimal difference. Although like it's been said everywhere at least one of the mounts will need to be changed.(good thing i have a mig welder)
Stuff about Florida
If you have an automatic right now that should bolt up to the zetec just fine.
Even if you were going to a MTX75 as long as you had an auto they use the same axles.
Awesome thanks for confirming. Now for the motor mount(s). I know one of them bolts on. But the other 3 I'm guessing weld on or do they bolt on. Any tips for mounting the dohc engine I'd presume this will require some custom work. Also if the ecu I'm swapping in doesn't have a chipped key will I be able to leave the old ignition switch alone.
/人◕ ‿‿&#65
I didn't realize you had an auto. I don't know the transmissions codes well.
There is only 3 motor mounts. Technically 2, and the 3rd is a dogbone that goes from the trans to the front subframe.
The passenger engine mount IS. DIFFERENT.
The driver side mount (under the battery) I'm not too sure. But I would just change it anyways since it bolts to the trans. When I did my SVT swap the black bracket was different and needed to be trimmed. The studs coming from the car were longer on the SVT. Just saying this as an example.
Now, if you are changing only the engine, you will need a automatic zetec ecu, all the engine bay wiring (from the driver side junction plug behind the splash shield, all the way through the engine bay to the ecu on the passenger side.
Just be sure to get an auto zetec from 02+. I think 00-01 used a different GEM and the plugs that go to the ECU were a different style. If you get an auto zetec ecu and engine from a 00-01, you will need to swap almost all the wiring.
Thanks for the help. I'm going to go to the local ford dealership to talk to one of the techies to 100% confirm everything. I'll post pics (lots) when I start the project.
jester547, I'm actually in the process of doing the same motor swap as you. I picked up a 2003 SE with the 2.0L SPI that dropped a valve seat. These SPI motors are really over priced in my opinion (mileage compared to $$) at least in my area. I'm going to be putting in a 2.0L Ztech out of a 2003 in place of the SPI. I'll try to keep my progress up on here, I've already got the motor out of the car just waiting to pick up the Ztech.
Discussion Starter #9
If you need any wiring harness or anything else just let me know. I have access to On demand so I have tons of info. Lets try and make a thread greater than this one http://www.focusfanatics.com/forum/showthread.php?t=156676&page=1. Also check out http://car-part.com/ they list parts from wreckers all over north America. For instance there's a 2002 engine in rome ( about an hour and a half from you) for $400 with only 28k miles on it. (it's at Don's Auto Recycling Center, Inc. ) I'm lucky cuz i found a wrecker here that will deal, he quoted me $250 for a engine if i buy the ecu and wiring harness as well. Oh and I went to the dealership today, they had no idea about the mounts ( they said they'd be different, but he didn't know which once specifically). But they cleared up the key problem. You won't need the original key from the new ecu to program it to the old key. The service guy said it's 99 bucks to get it reprogrammed. So I gotta see if a local place can do it for cheaper.
I'd be willing to help you with a how to guide that would clear up future issues on this swap. zI too have access to on-demand and I actually used car-parts.com to find my motor from a local salvage yard. This isn't necessarily the best way to locate a used motor, but this time it worked out in my favor. On the reprogramming of the ECU this makes sense because this is how we did a charger at work. Granted there were alot more issues with this swap then you or I will have with doing the SPI to Ztech. We swapped the 3.5L out of his STX for a 6.1L check it out http://www.thejunctioninc.com/mainG...ake=Dodge&startModel=Charger&startYear=2007-1
EDIT: One other thing, I took the motor out the bottom with the suspension and wheels still on the ground. Essentially I just picked the body of the car off of the engine.
Discussion Starter #11
Also i forgot to mention this, but it makes sense, the focus came with either engine off the line it was an option. The sub frame motor mounts wouldn't be in the same place or the same, but the techie was saying they should just unbolt and the correct ones can be bolted into the correct place with no modification. All fine and dandy, but they still couldn't tell me which mounts exactly were different so it'll be trial and error. So two trips to the wreckers will be necessary don't wanna buy all the mounts if I don't have too. This forum will be great your doing an spi to dohc and I'm doing a standard sohc to dohc, all bases will be covered. The sub frame design is awesome at least now I won't need an engine hoist just some 2x6 and a jack. But what I will do is pull the sub frame with engine intact then transport it to my shed where I can use my ratcheting wench to hoist it onto an operating table to work on it at waist level. I bet that engine swap was allot of work. Looks great though. Anyway I'll post pics Monday night ish next week when I pick up the engine and pull the old one.
Here are a few pictures, but I'm not sure what I'm going to do knowing I need the cat and flex pipe. They're $500.00 new and I believe it's illegal for salvage yards in the great state of NY to re-sell cats... might be rebuilding the SPI. [wrenchin]
Discussion Starter #13 (Edited)
Ebay... I wouldn't rebuild a sohc if my life depended on it. It'll cost more in the long run than the dohc will to put it in even with the cat and flex pipe.
http://cgi.ebay.com/ebaymotors/Ford...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
http://cgi.ebay.com/ebaymotors/2000...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
I didn't think to check that, s**t I bet soch to dohc is same way. Hopefully fingers crossed i can get a cat from a local wreckers. The flex pipe I'm not so much worried about as it's cheap. Thanks for pointing this out I would of had the new engine almost in and found out.
Sure thing, thanks for the links.
EDIT: Alternators are different as well...
Discussion Starter #15
I'd think that all of the engine components other than maybe the starter will be different. But hopefully when the wrecker quoted me $250 that's complete and not just a bare block.
Usually, around here anyways when you buy a salvaged motor, you'll get the block, head, fuel rail w/ injectors, both manifolds, flywheel, and a pump or two if you're lucky. The starters, alternators, and ECU (which needs to be reprogrammed in my case) are usually sold separate.
Discussion Starter #17
This idea started as a cheap and easy one. I'm gonna have to try and stretch my money far to do this project.
Aurelius Pardus
here. Read through this thread. I started at page 2 for you as that's when the work begins.
Same scenario as the OP. The transaxle mounts (upper and lower) are the same and I know since you're using the same transaxle the axle shafts all mount up with the old stuff. Passenger mount, both parts will need to be zetec.
This should answer any questions by the end of your read.
http://www.focusfanatics.com/forum/showthread.php?t=252790&page=2
Hatch Nation #136
I'm in the process of moving over to an SVT header. If you haven't solved it by then I can sell you the exhaust manifold through the cat cheap when I pull it.
1 - 20 of 70 Posts
