1 - 3 of 3 Posts
2002 Ford Focus power windows will go down from master switch except drivers window and the other switches on the doors will not work
2002 Ford Focus power windows will go down from master switch except drivers window and the other switches on the doors will not work[/QUOTE
Check your fuse box . if that doesn't work pull door card off and check connector. I had broken pin in mine. Good luck.]
The system has one fuse for front door window motors (F55) and one fuse for rear door window motors (F54). Since front passenger and rear windows work from some switches the problem is not a fuse. I would suspect you need a new master switch which is very easy to replace. You should be able to get a switch in a salvage yard for $5.
For a 2 door master switch but 4 door is the same (you dont really need to disconnect the lock switch):
Good luck
Paul
1 - 3 of 3 Posts
