Hi All,
I have a 2002 MK1 Facelift Focus and recently had the left fog light blow out; I finally got round to purchasing a pair of LED ones and when replacing them I found that the connector for the one I needed to replace, looked like it had burnt out; what could have caused this and would it be worth just replacing the connector for a new one?
I have checked all the fuses and also checked to see if there are any signs of moisture damage but all seems to be ok.
The other issue that seems to have occurred is that the main bulb on the same side (passenger side) blows out quickly; only this time the connection for the main light is fine and there looks to be no immediate signs of a problem (again all fuses are ok and the connection is perfect when I opened it). Could the two be related in some way as they are on the same side? Is there something else I can check or do to ensure that a new fog light connector does not fail and\or another main bulb doesn't blow?
Cheers Guys
Cheers Guys
