1 - 7 of 7 Posts
My wifes 2002 Focus SPI heater switch will only work on the high setting.
Only information I could find talks about a blower motor switch module....which sounds right as the first 3 settings on the switch do not work,but the switch bypasses the faulty fuse in the module and runs direct on the high setting.
I called AutoZone and it will have to be special ordered,alas they do not have a picture of the item in question.
Am I on the right path with this?
If so,does anyone have the correct part number for the module?
Help appreciated!
Think there is a resistor pack involved in this problem, behing the glovebox somewhere, do a search on resistor pack...
Yeah,I think the resistor pack actually attaches to the module I am looking at....
Unsure which part I need?
Focused Focus
Thats the most common part. Pm me for that.
Those resistor packs blow.....they get hot and a circuit burns like a fuse. When you switch to hi speed, the resistor is by-passed.
If you remove the thing, often you can see the burned part. It's the most likely thing that failed, causing that symptom. You can also check it with a VOM.
Discussion Starter · #6 ·
My wife said that before it went,it smelled like something was Hot....Im assuming the resistor went.
Anyhow pm sent Mike.
Help has been appreciated!
1 - 7 of 7 Posts
