Hello all, new to the forum and dohc timing. I was driving my focus down the street after having just pulled away from a light when the timing belt broke. I knew it was because I pulled the cover back a bit and confermed it on the side of the road. I had AAA tow it to the house and that is where the trouble began. It is really starting to make me look like a mook.
I have had it apart 4 times now and i am following directions from this site and ot just wont fire up. The first time it seemed like it was turning right but wouldnt start, the second time it sounded like it had no compression. As did the third and forth.
I am using the bar for the cams and the pin for the crank. I set the cams and place the bar, stick a screw driver in the number 1 cylinder and turn the crank till it is at the top then put the pin in and turn the crank till it stops at the pin. Put the belt on and put everything back together and nothing.
