1 - 3 of 3 Posts
Hey guys I'm new to this place and just joined to get some help.
I have a 2001 focus se spi. I have been try to fix this car for close to a year now and have made progress then quickly lost it. Right now the car idles a little high in park and will run decent in gear tho it does lope a little. As it gets warmer the idle gets worse and after about 10 minutes of driving it will start trying to die at idle. But if you put it back in park the idle comes right back up and idles fine, just high. In the past few months I have replaced the evap purge valve, plugs, wires, oil change, fuel filter, made sure the fuel pump filters aren't clogged, and pcv. Not sure if it is related but the check engine light never comes on and it wont connect to a code scanner.
Thanks for any help you can offer,
Jojo
Moved to General Tech Chat
Welcome!
1 - 3 of 3 Posts
