1 - 6 of 6 Posts
I have a 2001 SE 4dr, I want to put in a better system but I want to make sure I can change the head unit out before I do anything. Its the stock cassette-tape player. Its about double the size of a normal head unit, would anything else fit?
Welcome[welcome]
And you have a 1.8 din. So any single din will work, but you will need to buy a mounting kit. A double din will work but it will require you to do some cutting and custom work.
thanks, I was reading about doubles and 1.8 dins. Where can I buy one of the adapters?
Im also from Wichita, but moved in about 4 years ago.
Flat Black King
well i see you live in houston now welcome to houston and welcome to FF.com. hop over to the texas forums and you will see there are a few of us here. There are alot of audio places in houston to buy those adapters. just pick one and go ask to see how much
Woah another wichitan! sweet
Well I would say for you to check out crutchfield.com. They give you step by step instructions, wire harness, and mounting kit with your purchase of a stereo.
1 - 6 of 6 Posts
