Hey guys,
Small introduction: Father has been auto tech for 50+ years. I go to school for it also and work on customer cars there. I also work at a Hardware/Parts store.
_______
I own a 2001 Ford Focus SE Zetec engine DOHC.
My sister has the car way before me and it sat for a while after, well she broke a key off in the ignition. So we reprogrammed it and left half the key in it, was cheaper than replacing it and such at the time. Well the security system seems to not like you have you reprogram anything in the car. This hasn't been us, we have seen others with the same problem.
But it does work most the time, until something drains your battery. In my case it was an alternator(and the battery wouldn't hold it charge after charging it), I got 3 years out of it and decided it was just going replace that. So we replaced both of them. This was back in June, well after we replaced them both the car would not start. We keep it simple and went straight to the fuses, on my engine compartment fuse box F8 is the Ignition fuse. We pulled that and put it back in. Works like a charm.
Well what is wrong with it now? Nothing, but in the last month I had a customer come to the store with same issue, we sold her a new battery and wouldn't run. Removed fuse and it worked perfectly.
Friday my father had the same thing with a customer car. Now is the time here in Michigan where battery are taking poops on us and I wanted to see what you guys think is causing it. It only happens to reprogrammed keys here.
Any ideas.
_______
Any ideas.
