Hi Guys,
I was driving last weekend and while trying to accelerate the car would bog down like it wasn't getting any gas which it did have! At half throttle was running fine but after that it would almost die. I get to my buddies house and when I go to leave I cannot start the car up again. He has a basic diagnostic computer and it throws the P1233 code which I have been reading about the FPDM possibly being bad or the pump itself. After running the code I went and got a new FPDM put it in and unhooked the negative to reset the computer. Tried to start it and same problem turns over but won't start but the code is gone now. When you turn the key you can hear the pump kick on for about 1-2 seconds then stops like its up to pressure. Just to check we unhooked the fuel line from the rail and turn the key and gas lightly squirts out so it should be getting some gas. We tested spark and put new plugs not the issue. I checked the inertia switch and it is not popped out so thinking thats not the problem . I am at a loss if it has spark and gas getting to the motor why won't it even sputter like its trying to start? Anyone have any ideas?
Thanks,
Justin
Thanks,
Justin
