Okay, daughter calls me with dead car, I figure out it is the fuel pump, replace it, sure enough it was. However, upon starting it back up I get the weirdest ticking (light metallic, sounds like valvetrain, not rod knock) Pull the plugs, 3 of 4 wires disintegrate on me, the plugs look wrong and number 4 is not firing....it's wet when I pull it (Plugs were for the T bird Super coupe) replaced all that, but still the annoying light ticking. I did a compression check and had 105, 25, 105, 0. The coil is good, as is the ECU, I assume the crank trigger is also good or it wouldn't run or it would give me a code (no codes so far either).
My question is, is this related to this valve seat "dropping" I have been coming across on the threads? If so, is the head savable? The rest of the car is fine with about 110 K on it and it seems to be okay everywhere else. I have the ability to do the R&R myself, and we have some great machine shops in town, or should I just go to a rebuilt head from a shop?
Thanks for the Forum btw, you all helped me isolate her problem.
