Guys I have this front end clunk that is driving me nuts. When I put the car in gear and accelerate it seems to clunk on both sides. Some times when I hit a bump. I have had the front end up on stands and everything appears tight. I have also had the front end up while supported under the control arms and I can't get any movement or noise when trying to force the tires about. This is what has been replaced in the past couple of months.
1) Control arms
2) Front struts
3) Sway bar links
4) Right side and rear engine mounts
5) Transmission mount
6) Outer tie rod ends
7) Drive axles on both sides
Any suggestions would be appreciated.
Thanks,
Jim
1) Control arms
2) Front struts
3) Sway bar links
Thanks,
Jim
