After about a 15 minute drive, my 2000 Focus began to overheat. After I pulled over and opened my hood, there was coolant all over the engine, coolant reservoir, etc. as well as it leaking onto the floor. It is difficult to pinpoint where the coolant is originating from. After some online research, I discovered that the thermostat housing is a common problem, however is there any other common problems I should consider before I attempt to check the thermostat?
I have the 2.0 Zetec engine with 131k miles. I haven't had any other problems with the car and it was running very well up until this happened.
I know I a sparse on details so any suggestions would be appreciated. Thanks.
