1 - 11 of 11 Posts
· Registered
This may be a odd question but Ill be getting a focus wagon soon and I've always wanted to get into doing mods on cars and I would wanna start with coil overs and wheels as one of the first ones. Think is I don't see any builds on this model do the coil overs for the sedans fit the wagon as well? what are my options when it comes to this?
· Registered
For the front most likely yes. I'm pretty sure the rear setup was unique to the wagon
There's a wagon kit here... seems expensive tho
You can get lowering springs for $1k less than that, it just depends on your goals
· Registered
Would I have to worry about anything else being messed up by lowering springs suspension wise?
· Registered
No, you'll just need an alignment after and should be mindful if you slam the car, you'll need to figure out how to get camber back in spec (it's non-adjustable stock).
The biggest challenge is going to be finding parts for the rear, the wagon is unique. You may have to look around Europe since they had a wider wagon (estate) offering including the ST170.
· Registered
Discussion Starter · #5 ·
I think I just wanna get rid of the wheel gap for now so springs may be my best bet I suppose
· Registered
Agreed - Don't forget dampers too or the stock ones won't last long on lowering springs.
Coilovers are great, but say if your budget is $500... springs and better dampers at that price will be far better than any coilover close to that price range.
· Registered
Discussion Starter · #7 ·
I did not have a specific budget but I did not wanna get myself into more than I could handle considering this car would be my daily driver. Are there any springs and dampaners you would suggest
· Registered
You're unfortunately limited with the wagon, without trying to mix and match parts. Looking quick, this is what I would suggest to get you down ~1.5" and not be overly harsh:
Dampers are tough. I can find some decent front ones (KYB AGX) at Tire Rack, but they only have GR-2s for the back.
· Registered
Discussion Starter · #9 ·
if im trying to daily this car would this be a reliable set up or should i just look into trying to find another project later on
· Registered
Nothing unreliable at all about quality springs and good dampers. If you drive on terrible roads that would be a bigger concern (if you want your car any lower / stiffer), but there's nothing that will cause reliability issues if you install those parts correctly.
· Registered
Discussion Starter · #11 ·
so to be clear I need two seperate sets of dampaners for the front and rear and if so could you drop links sorry for asking but im a little new to things like this and i just want to be sure i get it right
1 - 11 of 11 Posts
