2000 Ford Focus spins over but won't start.
I have fire and when I take the fuel line off at the rail I have pressure there.
I tried spraying a little carb cleaner in the air inlet and see if it would start and nothing.
It has the ZTEC engine and since the problem I have replaced the follwing.
Coil Pack
Fuel Pump (not the whole assy, just the pump)
Fuel Filter
Installed a new timing belt and pulleys (idler and tensioner)
The fuel pump does run when the key is turned on also.
The Emergency fuel cutoff isn't tripped
Any help would be appreciated, I have ran out of ideas... [?|]
Coil Pack
Fuel Filter
