Hi, I was curious if anyone has had a coolant leak on the Zetec engine located behind the power steering pump right below the valve cover (the upper left, front corner of the motor right below the valve cover behind the power steering pump. Its dry around the water pump but looking above the pump to the upper back of it you see a little green. Hoping its not a crack.
I was going to wait till the weekend to investigate better.
Thanks! Rob
Also I pulled the plug wires because I have seen a lot of threads talking about the freeze plugs. They were ok, all dry.
Thanks! Rob
