1 - 4 of 4 Posts
Daughters car is a 2000, SE, with 83,000 miles. She said she was driving along and all of a sudden the car loses power, the gauges all drop to 0, radio goes off, and then magically it comes back on again. Happened twice within 3 minutes.
Of course, when I drove it, nothing happened. I'm guessing it is an electrical problem.....battery is 3 months old and connections look good.
Any thoughts from you guys?
Thanks,
Clay
Any warning lights on the dash at all? If it seems like all the power is gone, I would put down the ignition switch and/or the wires/connectors to it, as a suspect.
I would also check the power distribution fuse box under the hood and remove/check/reseat the fuses as a start.
And since the battery was replaced in the past three months, I would check/wiggle to battery cables while the engine was running to see if there's anything odd going on there.
^^^^ As penquin said above, that would be my guess as well...def. gotta be electrical going off that way. The fuel pump recall been checked???
Actually, Penguin said something about the ignition switch that made me remember that we had to have the ignition switch replaced about 6 months ago. The possible loose wires to the ignition switch makes sense for it to basically shut-off and then magically start up again. I've asked my daughter to pay attention next time and see if it happens when she turns a particular direction or not.....while I either try to find the card for the locksmith that replaced the cylinder or figure out how to remove the cylinder and check the wires myself.
1 - 4 of 4 Posts
