1 - 20 of 21 Posts
Ok guys need some help.... i have a 2002 ford focus... fully built ...cgi, manely rods, diamond pistons, clevite bearings, oil squirters, full turbo system...ect... ect..ect... tuned by Tom at forcus power. all of this only had about 5k on it when i spun the first bearing....Well now in the past 3-4 months i have spun or messed up the #2 rod bearing 3 times.... The first 2 times the rod turned blue and found out that the # 2 main wasnt clearanced right.. well had scarborougho who is pretty well know through the racing industry rebuild the bottom end Custom cut the crank to fit the bearings re finished ... crossed hatched.. ect.. ect..ect. well i got about 70 miles on the motor and again got a knock. hadnt even used the high boost... car is tuned for 25lbs of boost and was only running about 13lbs. so i need some ideas as to why i am having so many problems with the #2 rod bearing.
just so you know... things we have already checked... oil pressure.. i have 32 at idle and goes up accordingly...
I have been running a fram oil filter and found out that they supposedly suck.
I run 15-50 mobile 1 synthetic oil. and run 93 octane fuel.
I have a j&s and did not see it do anything but flicker for a split second when i let out of it.. has done that since i put it in (tom said thats ok)
Please help me come up with some things to check... and help me solve this demon so i can drive my car.
Well you are going to have to take it apart to see what the problem is this time. What did you have done to the rod the first three times? Was it replaced or just checked out? I wouldnt have trusted the rod after the first time of it turning blue from being overheated, even if you machine it back to spec, I wouldnt trust it.
Discussion Starter · #4 ·
mcnews built the motor originally...
the first and second time i just checked if it messed it up and since it didnt i just put a new bearing in it. (I know... not suppose to do that).. the third time i had scarborougho rework all of the parts.. and they said that they rebuilt all of the parts and cut them to fit eachother just like they do an all of their race motors.... i asked about the blueing and they said "yeah we do this all the time well fix it to make sure its safe. You wont ever have to worry about it."
they (scarborougho) have it right now and said there was no scarring or the #2 bearing this time but you could tell that it had been effected.
This time when you rebuild it, I would first take a look at the crank and block oil passages and make sure its not an oiling issue. I put together a new CGI block and upon cleaning it prior to assembly, I found an oil passage partially clogged.
To be on the safe side, I would just pick up another stock crank and new rods, or contact Manley to see if they would sell you one rod. Definetly get the block checked out though.
IMO... sounds like its an oil related problem. My guess is that your bearing is somehow not getting the amount of oil that all the other bearings are and is heating up to the point where it hugs the crank and goes for a ride with it... I think this because you are saying the bearing/crank journal looks blue-ish which is a real bad sign of high temps on metal... ask any racer what a burned up flywheel looks like... I would be flushing out the whole oil system and trying to manually clear any obstruction just in case.
just my 2 cents... good luck & keep us updated!!!!
Discussion Starter · #7 ·
we thought of that and on the last build up they did all that.... cleaned out and made sure there was nothing in the passages..this time the said it wasnt a blueish color.
FF Affiliate
I agree to me it sounds like the bearing is getting some oil but not enough , you need to remove all block plugs , squirters and there is a rod that you can use that will go into all oil galleys to check them and make sure there open
Resizing the rod and grinding the crank to proper size does not bother me at all and if sized correctly would not be your problem
Keep in mind every time you resize a rod it gets shorter
Discussion Starter · #9 ·
ok so where do i get this rod to check the oil galleries? and what specifically do have to do and check?
FF Affiliate
Bring it here and I will go over it with you OR places like hobby shops and automotive supply places sell long small brushes that will also work well , You want something about the size of the hole and take out all the oil plugs so you can see through them and see the rod coming through to the larger main holes , DO NOT just blowthrough them
Almost all the CGI blocks we have done had a large amount of crap in the oil holes
I agree 100% Someone is over-looking a small detail
Discussion Starter · #12 ·
I dont have the car right now.. right now i am just doing some homework to help them try to figure out how to fix this car.
Discussion Starter · #13 ·
ok well between where my car is at and your guys help and toms help.. we have discovered what we think might be the problem... according to tom it is a very common problem with the cgi blocks that the #2 oil journal has shavings in it and clogs up the oil journal..(from the factory) the only way to fix this is to put some sort of rod whether it be a drill bit or long allen wrench throught the oil journals.. And according to the sho i have my car at.. that is the only journal that you cannot blow through on my car... so im gonna try to get my motor out of my car this weekend and see what is clogging up that journal... hopefully that is the problem i have been having and this fixes the problem once and for all..... but just for future references make sure if you get a cgi block that you stick a rod of some sort through all the journals.. air and brushes will not work... a metal rod.... wish me luck ill keep you updated when i find out more.
Thanks for all the input...
[ohcrap] who told you to put that in there? my car is running similar power to yours and i use 5w-30. alot of the other guys with my car that have alot more power than i do, the highest they use is 10w-30. just wondering why you are running such thick oil. maybe that is why your passages are clogging up. hope you get it figured out though. very nice car and build up.
^^^^^I was thinking the same thing. I would never use more than 5w oil in any of my cars with less 100k miles especially a new engine. Although if the problem was the block and/or the rod I think the problem would of showed up eventually [dunno]
Discussion Starter · #16 ·
tom told me thats what he used in his car... so i figured it was pretty good.. ok so do you guys use synthetic or just regular oil? and what kind of oil filter do you use?
FF Affiliate
Because 50wt gives more protection for harder loads , I use 50wt is almost everything I own , the guys in the colder areas I would use 50 in the summer and 30 in the winters
ok, i was just wondering. i trust tom because he is the $h!t and knows his stuff. i use full synthetic 5-30 year round and i am in midwestern missouri
Btw Is that a focus?
nope, srt4.
makes sense. thanks for the clarification tom.
Discussion Starter · #20 ·
nope, srt4.
Thats gotta be a crazy fun car....[driving]
thats an insane amount of torque.....
1 - 20 of 21 Posts
