41 - 60 of 102 Posts
Discussion Starter #42
Im leaving egr, I just want to get this up and running all the little stuff is killing my budget, also I hate red valve covers but I also do not like blue haha. It will be changed later on
Discussion Starter #43
Felix now you have got my curiosity, maybe I should just remove the egr because Ive read Tom will delete it in the tune anyways. Ill wait until it's tuned- any pros or cons other than cleaning up engine bay?
w/ my magic bag
No burnt exhaust gases into the cylinders + after awhile you'll find the t/b getting stick & have to clean it out w/ carb cleaner/tb cleaner, at least on the cable operated ones. I'd also delete the rear 02 sensor also.
Discussion Starter #45
Okay well that sounds good to me, not sure about the rear o2 I have the obx header so I forget if I run one or two.
So mote be it
If i recall correctly, an aftermarket header wont have provisions for the erg and blocks it off anyways and the tune from Tom shutting it off from the ecu side, i dont think you actually need to buy the egr delete kit. Ask Tom his opinion on that before spending more money...i may wrong but wont hurt to ask
Discussion Starter #50
Thanks I will definitely do that, I LIKE saving money. Also does any company sell a cheap tb spacer for the duratec? The throttle is hitting the intake at wot. I didn't see people having this issue but it is a stock tb.
w/ my magic bag
Stephen you mean the rear 02 sensor.......not the egr. Your there, delete the egr & by pass the coolant passage for the egr & install a plate.
Discussion Starter #57
Thanks guys, yeah Im very excited for the first start up, Ill definitely make a video. I also picked up a magnaflow catback from the junkyard hopefully that sounds decent. Couldn't beat 30 bucks
What do i put here?
Awesome man! Who is going to be doing your tuning?
Discussion Starter #60
Made another bung on the header for the wideband. Should be able to read well enough i hope. Also learned that i had to turn the iac upside down but the throttle will still hut the iac bolt heads and i think even if i shave them down. Any suggestions? About to make my own spacer
