Here is my new heat shield for the alternator. It's made out of aluminum kick plate for a door lol. It worked better than I thought it would and I made a tab that allows it to be bolted directly to the block behind the engine between the downpipe and the alternator. Don't mind the 4 holes. That was for a previous mounting idea that I scratched. I just didn't fill the holes.
I didn't take any pictures of the install but it took me all day to do. Everything went fairly smooth. In one of the pictures you can see the heat shield installed. I should have extended it over the top of the alternator between the manifold. I might do that soon.
I used the massive speed throttle body adapter as a vacuum block for my boost gauge and somewhere to pull for the diverter valve. The car runs and drives but tuning will be a long and painstaking process I'm sure. I'm going to continue to tinker with the car because I have lots and lots more to do. For now though I'm leaving the engine mods alone. Here's the full and (I believe) complete list of engine mods:
• 2.5 Fusion engine swap with 2.5 cylinder head
• 2.5 Fusion single runner intake manifold (no intake manifold runner control)
• VCT delete
• 2.3 valve cover
• 2.3 oil pan
• 2.3 sensors (retained all)
• A/C delete with idler pulley and shorter serpentine belt
• Massive Speed EGR delete plate
• Crower stage 1 cams
• Fswerks stage 2 turbo kit with gt2871r turbo and 12-14 psi wastegate
• Siemens 60lb injectors
• PCV delete (vent to atmosphere and plugged intake manifold)
• Massive Speed throttle body adapter (tapped for vacuum lines)
• Molnar connecting rods with factory 2.5 pistons (stock compression ~9.7:1)
• Mahle piston rings gapped to 0.018 (top) and 0.022 (second)
• Mahle rod bearings
• Honed cylinders
• Lapped valve seats
• ARP head studs
• ARP crankshaft pulley bolt
• Cosworth balance shaft delete
• 180° thermostat
• Energy suspension rear motor mount inserts
• AEM wideband
• Exedy stage 1 clutch and flywheel
Any questions or want specific pictures of the build, ask away.
