1 - 4 of 4 Posts
I was wondering if anyone had error codes when they have done the throttle body swap to an SE from the 2.3L . The posts and videos I have seen have all said plug and play. An engine fault code message and that the hill assist code not be activated. My only thought is if this is not compatible with flex fuel models.
The short drive I took it on the increased throttle response was immediately noticeable so I would love to be able to find a solution to this if possible. Felt like a whole new car.
What part you have #
The part # you want is a GB8Z-9E926-A
That is the one I have. After stepping back for about an hour and a half I discovered I didn't get the MAF connector plugged in all the way. Corrected that, erased the codes and discovered my gas pedal actually does work. All I wanted was to get rid of the 3 second delay in response. Wanted to get my bolt on parts done before messing with a tune.
1 - 4 of 4 Posts
