ok so i recently and unfortunately had spun a bearing so i bought a cheap a 05 2.0l from the junkyard and swapped it into my 05 ST. after completing the swap the car started and ran ok a few times and then somewhat gradually started to get harder to start and now will not start at all. cranks fine but no start. the engine was from an atx where as mine was an mtx and for a brief moment i had a check engine light which came up as p0320 regarding the crank position sensor. ive checked all the wiring including grounds aswell as replacing the crank sensor but now and lost...
any help would be much appreciated thanks FF[thumb]
