1 - 19 of 19 Posts
Prob. worn tumble flap clatter, watch the actuator & the reduction in noise as you rev it should correspond with them opening.
w/ my magic bag
That vid was a 20 motor. Its the imrc flaps like Roger mentioned. Undo the vacuum line going to the passenger side imrc electonic/vacuum switch at the top of the manifold & be sure to plug the intake line & you'll see & hear the noise goes away. So this means you'll need to= 1 r&r a i/m or just remove them. And when you do I'd recommend you replace the pcv hose since you'll have the i/m off.
BTW you call it a "electronic/vacuum switch"; I call it a solenoid.
The engine in the video has imrc and imtv solenoids so it is a 2.3 right?
@Sith
I agree with the guys above, your imrc flaps inside the IM are making most of that noise. Also, my IMTV flaps make noise too. Disconnecting the electrical connector or a vacuum line from a imrc or imtv solenoid will change the position of the actuator arm and the flaps and make much less noise. Disabling imrc will set a DTC and a CEL. Disabling imtv does NOT set a DTC or CEL.
http://www.ebay.com/itm/BRAND-NEW-O...ocus|Submodel:ZX3&hash=item53ff714372&vxp=mtr
Engine is 2.3 its an ST
sorry guys i was geting on the car when i make last post, te engine is a 2.3
here are a pic (sorry is dark anda can't have a nice shot)
and second my mechanical skills are not the best what mean about " flaps inside the IM"
i has to find a ford specialized mechanical for a second opinion, take it to the dealer its could be realy expensive here
Google "duratec tumble flaps" to find pictures easiest.
They're flaps in the intake manifold near where it attaches to the head. Closed at low rpm & open as rpm increases, they help low rpm performance.
w/ my magic bag
I'd find a good independent shop to replace your i/m.
Discussion Starter #11
Ok whit this there all more clear, I will cheque after work
Tanks
Discussion Starter #13
Relay tanks guys
I unplug the vacuum and sound disappear, but!
As soon a turns of and restart the engine the sound start again, now I have to find a new im, this could be a good excuse to install a cosworth one? Ne tho $$$$$
I recommend you replace the intake manifold with a Ford IM like this->
<< OR >> if you have future plans to put in more time and money into your engine performance and other engine modifications... A Cosworth or Cosworth knock-off intake manifold will require you to have a custom PCM Tune. A tune is a great thing, if you have the desire and about $400 to do the PCM tune.
A tune is also a great thing without or with few engine mods.
w/ my magic bag
I concur w/ this^^^^^^^^^^^
Discussion Starter #16
on that link the manifold is for a 2004 would be compatible on 2006??
w/ my magic bag
It should be, but I'd check it out 1st. I'd also look for a better price too.
Link's only useful for generic intake manifold picture.
One for your engine type would be correct. '05-'07 2.0 should all be the same, actually don't know about subsequent variations for sure - through '11 might fit, you'd have to check listings to be sure. (as long as the electric TB bolts on the same way, they're prob. identical)
1 - 19 of 19 Posts
