Hello Everyone, I am new to forums so please forgive me if I my thread is covering a topic previously discussed. I did take the advice of one of your members and used the search bar first before writing this thread.
I have a 2001 Focus SPI engine, bought the car from a dealer who said the car was traded in by an older couple upgrading to newer car.....you know the story I'm sure.
When I tried the car out in a test drive the car ran out well, a bit low on "zip" but accelerated satisfactorily, engine ran smooth and quite quiet for an SPI engine with 155K on it, no misses, no leaks.
When I got the car home I checked the PCV valve, was clogged so I changed it for a new one from the Ford dealer, checked oil (it looked clean but could use a change), changed spark plugs (worn to .065"), changed wires, air filter, topped up all the fluids. After 3 weeks of running I decided to get the oil changed since I didn't know when it was last done and with what oil.
Changed the oil and filter, used a Fram PH3600 filter, and 5W20 oil, had this all done at a reputable oil change facility. Upon starting the motor the engine immediately sounded like a diesel motor, making all kinds of "clattering" noises in the engine! The noises seemed to be coming from the head area (valve train area), so over the next 4 weeks I have been trying out different oil grades to see if a thicker oil would make the difference, without success.
I eventually took the valve cover off, checked the lifters and they have since been replaced with new, new rocker arms and fulcrums. Upon starting the motor (with new oil) the engine ran very quiet and smooth. This only lasted for about 3 days and then the knocking started again, not as bad but still audible, and only from focused areas of the valve train area now, not all over.
I will be having the oil pressure checked before i do anything else, but I was wondering if any members have had this problem and what was the outcome, and could they share some insight on how this could be fixed without pulling the entire engine?
The engine by the way does not make the knocking sound when first started either in the morning or if allowed to cool down for a while, only once the engine gets to operating temperature. I orgininally thought it might be the oil pump (hot oil thins out) but won't know that until the oil pressure test is done.
Any insight would be greatly appreciated. Thank you.[?|]
