1 - 8 of 8 Posts
i went to start my 06 2.0 focus and i guess i didn’t hold the key to crank it long enough and it almost started but died, this has happened before and it mostly coughes a second and runs fine but this time it didn’t, it idles rough and revs rough and the the car shakes a bit, i don’t want to start it again in fear of fucking a valve or somthing, it’s getting towed tomorrow, any suggestions what it could be? i don’t think timing is an issue because of the timing chain
Try cleaning the mass air flow sensor. Simple thing to try, little lost if it doesn't fix it.
2007 Ford Focus ZX3 2.0 Duratec
My 07' w/ 254k mi does that often, it's cranks for 2-3 seconds, sputters for a few more, then smooths out. Been doing that for years. I believe it's a fuel issue. When my lazy ass gets to it, I will be changing fuel filter again and o2 sensor. Will update once done.
Actually what you have is likely a PCM programming issue. Ford had a TSB on it back in the day and they reflashed it if you brought it in. If the vehicle was reflashed there should be a sticker under the hood. As I understand it it made it much better but didnt quite eliminate it 100 percent.
Paul
1 - 8 of 8 Posts
