1 - 11 of 11 Posts
I just put a custom intake on my 05 2.0 duratec. i've noticed that it makes a wierd humming sound and bogs down some times around 50 and 55 when coasting. Just tryin to figure out why this might be. The car only has 11,000 miles on it. Could the filter need oiling? Any help is much appreciated. Thanks.
possible leak...are you letting off the gas as it bogs??...if you do that the throttle plate closes and the engine bogs down to idle, that may be it, not sure tho
yeah it it could be a leak. I bought all the parts from auto zone and modified the stock maf tube and put a cone filter on the end of it. kinda cheap intake until i can afford a good cai.
yeah i am letting off the gas as it bogs but it only seems to do it in 5th gear not any other gear when i let off the gas.
Its your A/C. Turn it off and watch the noise and bogging disappear!
i bet it's a leak... i need to check my cai for leaks, i have a good amount of hesitation starting from a stop
agree
ya its the a/c. wenever i turn it off n ride it obveously runs 10Xs better.wen i run ac my car hesitates cuz i guess i never use it HOPEFULLY lol.
yeah, A/C's suck! when my foci become a weekend car only and i get a work truck. my foci is ditching the A/C i think the last time i used it was like 3 weeks ago for like 5mins to cool my car down, and then i rolled the windows down. lol
Did you disconnect your battery for 15mins to reset your cars computer? That may clear up your problem.. I used to have a hesitation problem where I would be driving steady down the road at a constant speed.. and the car would randomly every so often hesitate like i had let off the gas.. but my foot was still there on the gas pedal.. I had my computer retuned by Focus Sport and it completely got ride of that problem. The car runs so much smoother. I also have never experiance that cold start problem either since I've had the tune. And my 05 has 52,000miles =P FS did something right =P
Also I never drive with my A/C on just because the car drives so horribly with it on.
Re: Re: 2.0 bogging down
that has nothing to do with your comp. what u are talking about is a common problem in 05 foci when driving in 5th gear around 50-65 mph and the car kinda just dies really fast ford knows about the problem and is working a fix there as been a few TSPs to try and fix it but nothing has worked 100% so far. u just might have been a lucky one
Discussion Starter #11
Thanks for all the input. The problem is fixed now. I relocated my cai and tightened everything up nice and snug so there are no leaks. I haven't had a problem with it for about 2 weeks now. Thanks again.
1 - 11 of 11 Posts
