1 - 3 of 3 Posts
am i going to have any rubbing issues with a wheel like this? also, what the largest tire i could fit without rubbing issues with a pro kit drop? i was thinking either a 215/35 or stretching a 205/40.
215/40 is about the largest tire you could fit there without fender modification, not 100% sure about that, you might need to go 35 series. the wheel itself should fit fine, just don't go bigger than 7 in wide on a 42mm offset or you'll definitely run into tire clearance issues
yeah well i might end up going 35 series anyways just because of pricing. 215 40's are really expensive.
1 - 3 of 3 Posts
