Temp has little to do with engine life unless it gets hot enough to do damage but to cool isnt an issue , I wouldnt go install a 160 thurmostat tho thinking that much cooler is better
Auto makers have started taking the temps higher more for emmissions then anything , they have found higher water temps help to burn off more making it easier to pass the newer each year federal giudelines and in some cases higher temps in some cars also helps MPG , dont know that I have seen this with the Focus tho
With a 180 I set the fans to 190, Keep in mind that if your cooling system is going its job the only time fans should come on is at low speed and idle , moving you shouldnt even need the fans on the car
