1 - 17 of 17 Posts
whats a really good 180° thermostat replacement upgrade that will help with performance? If anyone has one that really helps could you attach a picture and brand name and stuff. Ive been doin research but cant find much. I have a 2017 focus
2004 Focus Wagon, Zetec DOHC, Auto
The fan control would have to be changed in order to change engine temp. The stat just controls when coolant begins to flow, but has nothing to do with controlling the temps after it opens fully. Older cars were controlled by stat, but no longer the case.
Maybe you should try telling the manufacturers that....
They already know it, so your point is....????
These engines run happily at 220-230F with a 192 stat. The stat is fully open after about 7 degrees above its rating and the fans take over after that to control engine temp.
Without a tune, putting a 180 degree thermostat in, will offer no performance benefit.
OP, if you have the DCT trans I would not touch that car, you may need it OEM stock to get trans worked on.
I changed my thermostat to 180 for a tune specifically
Even without a tune I would still recommend the lower temp thermostat.
Less heat soak into the DCT seems to have improved its shuddering issue
My DCT shuddering problem always was worse after the car was up to temp, now it runs cooler with the new stat.
I dont believe the DCT really liked the factory thermostat.
Discussion Starter #11
Whats a good lower thermostat to look at? Could you attach a photo of what it looks like please.
I believe it was the below thermostat, did it about 3 years ago.
It took about 2 hours, would have been quicker if I had the right tools.
One of the bolts is really difficult to get to, had to use a 1/4 drive with some wobble extensions to get the socket in the right position to twist the bolt.
Not 100% but I think it was 8mm bolts.
Discussion Starter #13
Awesome thank you so much!
Look, I've had no issues with the Duralast or the DCT since the swap.
I had a 2014 Titanium that had 3 clutches replaced by Ford, none of them made it past 5 to 10 K before the shudder returned.
Traded it for a 16 Titanium and again the shudder started again with the new car.
After it started again with the 2016 I dropped the 180 in. (actual temp running about 190)
That was 2 years ago, still the car shifts perfectly.
Before I never made it through a Florida Summer without the clutch going to junk.
If anything Ford ruined a perfectly good car with the DCT, between both cars I went through 4 clutches.
I'm very happy with the car now that the DCT issues seem to be behind me.
1 - 17 of 17 Posts
