1 - 14 of 14 Posts
Just wondering if I could go with 18" rims with a 2"drop. I'm looking at 205/40/18. What you guys think?
More like 205/35/18.......You will also have to watch the offset..............It will def be too tight with 205/40 'cause of the drop...........
Peace...............
i've siad it before, and i'll say it again...
that's my zts, with 18x7.5 (40mm offset) wheels with a 2.7" drop. it's fine.
Discussion Starter · #4 ·
sorry to sound stupid but what is 40mm off set, is that the 40 in 205/40/18? sorry for my dumbness
no its not I cant explain offset but its not the 40 in the tire size it has to do with thewheel
Discussion Starter · #6 ·
I think I might just stick to the 17's for now, not to mention it's cheeper to buy new tires
Discussion Starter · #7 ·
That's nice, I like the rims. What kind are they?
Still doesn't tell him what are the width of your tires or the height is.............Is it 205/35/18?................Wild guess............
Peace..............
^^^Holllllllllller............
I think with your sexy svt you should be able to pull off a 205/40/18......Just 'cause you have the adjustable suspension so you could def custom fit the ride even if it rubs.............
Peace................
wheels are 18x7.5 velox vx8's
tires are 215/35/18 pirelli p7000
40mm offset... offset is calculated from the center of the wheel if you were to split it down the middle. if you go to tirerack.com you can see what offset is all about. they explain it pretty damn good on there.
1 - 14 of 14 Posts
