1 - 6 of 6 Posts
can you have this?
16x7(rota slipstream) with 225/45/16?
I want the maximum widest tire posible... i also plan on getting the sportline pro kit plus....
I plan on running those if that GB for rotas ever goes through....
I would look into your tire options, 225/45/16 are hard to come by, I pan on going with Hankook Ventus R-S2 Z212 (cheap and sticky)
more common size is 225/50/16, but these are quite a bit taller...
Problem is Rota's largest offset is 45mm. If you're using anything less than that you could be creating a receipe for rubbing and interference with that width tire (especially if its lowered or you intend to lower it).
im on sportlines with a 225/45/16 tire and a 16x7 wheel with a 42mm offset. i dont rub at all. i was expecting to rub a little on hard corners and bumps, but i was surprised to see that this combination works for me
1 - 6 of 6 Posts
