1 - 6 of 6 Posts
So i have the procharger running 10lbs on my car right now and i have the cfm overdrive crank pulley to run around 15lbs. would this be safe to do with a completely stock motor? car only has just over 18,000 miles on it and runs great now.
Guy running turbos run 18+lbs with proper tuning. as long as you have that and maybe a J&S your stock engine should be fine. 300whp has proved safe to run on a stock svt time and time again.
with a good tune you should be fine.... since a centrifical SC doesnt make its full boost until way up in the roms.
I AM DA FOCI FANATIC
....get a J&S good investment to save your motor
itll be fine, i was running 13psi and running perfect.. just get TOM to tune it.
1 - 6 of 6 Posts
