Hi Guys,
Apologies for the extremely long post in advance! Long time lurker, decided to make an account finally because I'm really lost when it comes to what to do next.
I own a 2004 ZX5 SVT w/ 161,XXX. After refreshing my front & back suspension about 4 months ago, my car started misfiring. Took it into my local mechanic, and he determined it was misfiring due to oil from the valve cover gasket seeping into the spark plug wells. $1500 later, we replaced the valve cover gasket, all spark plugs, all spark plug wires, and the entire PVC system ($500 from Ford!) Hoping that would fix it, my problem still persists. I noticed the VCT sensor was leaking as well, but he told me it's only leaking from the bottom O-ring and shouldn't affect my spark plugs at all (though I always see a small pool of oil where the sensor meets the cover on top). Before we began replacing anything, I asked him about the coil and he informed me they rarely go out, so I disregarding that suggestion.
Hopefully if I explain what I experience in the car, maybe that will help? So here's how it goes: While in any gear under load whether it's straight from a dig or going 75mph in 6th on the freeway, if I apply any throttle especially during WOT, my car starts to literally hiccup. The best way I can describe it is it feels like fuel is being cut off somewhere. It gets so bad that sometimes it will misfire 3-4 times in a row and mimics the sound of me hitting the rev limiter, and my car starts to vibrate pretty bad to the point where it feels like I have a broken driver side axle. I'm not necessarily sure if that's a misfire or not since I don't have a CEL from it.
Basically I'm at a point where I'm lost what to do next. Even my mechanic doesn't know. I've been doing a lot of reading on the forums, and I haven't seen anyone describing the same issues I'm having. Should I try replacing the TPS? I've already changed the fuel filter which I'm sure helped but didn't fix the problem. I believe the fuel pump is good, since it always primes as soon as I put the key in. I'm really contemplating replacing all of the fuel injectors since they're 10 years old with 10 years worth of crap built up.
Thanks guys, and sorry again for the long post!
