GF was driving the 140k 2001 Ford Focus DOHC SE wagon home today and stalled at a stop sign on a side street.
The blue 15 amp fuel pump fuse in the power distribution box was discovered slow blown (non-violently). All other fuses look good. The car will crank and all lights are normal, but obviously won't start.
She said there was a faint chemical smell coming from the general direction of the drivers footwell that instantaneously coincided with the quick sputtering stall. I'm guessing some melted wiring fault? Blowing fuses don't smell, right?
She was forced to drive through some rough terrain all day in a shipyard at work and was careful. On the way home she drove through a badly flooded roadway carefully. It was quite dark but don't believe depth was above hubs. I believe this may be the cause, although the stall occurred about 5-6 miles later during slower driving at the end of the commute home.
Should I try replacing the fuse first? See how far to get stranded again? I have read there is a fuel power module under the back passenger seat that has a grommet to the tank. I'm wondering if a short could occur there. Could water enter the connector causing a temp short?
Trying to rule out the circuit before i have to drop the tank if it's an internal short on the assembly/motor.
Thanks in advance!
Thanks in advance!
