I have the 6 speaker
4 in front doors 2 in rear doors.
Where are the other 4 speakers in a 10 speaker system ?
2 in each door, one on top of center dash, and a subwoofer.I have the 6 speaker
No. The 6-speaker setup doesn't utilize tweeters and subs like the 10 speaker does. Yours has 2 tweeters (one in each front door), and then 4 all-purpose (most likely 3-way, one in each door).So if I have the 6 speaker set up, all i have to do is buy some after market door speakers with tweeters and ill pretty much have the 10 speaker set up, minus the sub?
I'd like to learn more about this, can you cite your source.Then Ford warns not to stick a speaker close to the electronics in the dash.
(i forget why, it has something to do with the anti whatever?)
Where is that speaker located? I havent seen it in any focuses i have seen ( maybe because i didnt know it was there to look )I think she is talking about an unshielded speaker and the center speaker in the 10 spk setup is a shielded one so the magnet doesn't interfere with the MFT screen or other electronics. So if you were to mod your six speaker setup, use a shielded speaker up there and maybe even shield it some more.
They are not crossed over as such.The lower ones in all the doors are mids.
