1.0 ecoboost M1DA bearing cap bolts
379 Views 2 Replies 3 Participants Last post by  eatonm62
2
I need a set of main bearing cap bolts for my ford focus 1.0 ecoboost M1DA engine, can someone help thanks
Ruler Cylinder Office ruler Household hardware Font
Microphone Ruler Office ruler Wood Audio equipment
See less See more
1 - 3 of 3 Posts
Pretty much a Ford part. They are likely TTY stretch one-time-use bolts and commonly not found but at the dealer. if you use a regular bolt you have no idea how tight to tighten it, TTY torque specs do not apply to regular bolts and will fault your install. Being mains I would not go there at all.
ARP might make some that use normal specs and are reuseable.
I have had the same issue. See thread for work around.
1 - 3 of 3 Posts
