1 - 4 of 4 Posts
Hi all, I have a question about the clutch in my 2008 Focus SE. The clutch in my car seems to grab really REALLY high up, by that I mean I just tap the clutch (with some force of course) and it grabs, it's somewhat annoying, I'm getting used to it but from working where I do all other manual cars seem to grab near the bottom or in the middle. I know my clutch isn't bad, I've done the typical tests to check on it. My question is, do any of you have the same issue, is this normal, or could this be happening because of air in my system, if so how do I bleed it out or could this be something completely different that I'm not aware of? Thanks.
Sent from my Nexus 6 using Tapatalk
On the clutch if there is air in the system the pedel is spongy and might not come to top. To bleed you jack up the lt. front and pump the pedal there is you tube videos to do bleeding on Mustangs
1 - 4 of 4 Posts
