1 - 4 of 4 Posts
Alright so I want to install plasma led halo rings into my fog lights bulbs but I don't know if I can even take them apart? Does anyone on here have any info? Or am I netter off just removing the whole housing and making something to house the led ring on its own? I'm not sure, any info anyone has would be awesome thanks![:)]
The plastic black area around the fog lights snaps off (carefully) and I think it's a 7mm socket with a drive to get off the 4 bolts on each side. After that, unplug the bulb or remove bulb from housing, and your fog lights should slip right out, do one at a time so you don't switch them up and the bulb size is h11 in case you needed that
1 - 4 of 4 Posts
