1 - 1 of 1 Posts
SOLD SOLD SOLD
This is not a cheap Ebay knock off::::
I am selling my new retrofit Hid mini gatling gun 5000k set with halos for $200.00 firm free shipping. Please visit there sit if you have any questions on the set.
You will see this set will cost you over $300.00 when you add the Halos
All info is striaght from Retrofit inc website from where i purchased them from.
Bi-xenon Morimoto Mini Stage III Kit (H1)
They are new still in original box shipped in
I accept any credit card, pay-pal or Money order
You can text me at 717-991-4242
XENON MORIMOTO MINI STAGE III (H1)
EASY INSTALL UNIVERSAL RETROFIT KIT
$320.00 cost of new From RETROFIT SOURCE INC
Bi-xenon Projectors :
Qty: SET
Compatible Ballasts:
Ballast Igniters (Required):
H1 HID Bulbs:
Qty: 5000K SET
Shroud Style:
Qty: MINI GATLING GUN
Wire Harness:
Qty: SET
LED Halos:
Qty: 70MM SET
Description
Game Changer: The Morimoto Mini H1 Stage III Retrofit system is literally the number one selling kit in our catalog. Based around the latest H1 6.0 bi-xenon projectors and Elite HID system; it's most universal projector retrofit kit in existence.
Easy to Install: With the Mini H1's threaded mounting shaft that fits through the pre-existing hole in the back of your headlight reflector; They make retrofitting projectors easier than ever with little to no mods.
Morimoto H1 6.0 Projectors: Feature clear lenses to give them a wide, intense beam pattern with a sharp and colorful cutoff line. The new 6.0 version is enhanced with an all new optically advanced reflector bowl; improving low and high beam performance beyond all competing models. As the world's biggest Morimoto distributor, all projectors tuned to perfection here in our shop.
Morimoto XB35 Ballasts: Feature relocated igniters like OEM ballasts putting them far closer to the HID bulb. The lack of high voltage transmitted through wiring drastically reduces EMI/RFI (radio interference). Total system reliability is also improved by shielding the main circuit board from the static produced by these high voltage bursts on start up giving them a failure rate of less than .02%!
Morimoto XB H1 Bulbs: At the heart of the XB H1 bulbs is their perfectly aligned 100% Philips Quartz glass that houses a capsule from APL-USA. Using high quality halide salts from German-supplier Messer; the bulbs produce nearly the same luminosity (intensity) as the amazing Osram CBI bulbs at 5500K. No, you're not seeing things here, but yes you will be seeing everything at night.
Morimoto Relay Harnesses: Have fulled-sealed weather pack relays with revised circuitry, heavy-duty 14ga stranded copper wire, injection molded inline fuse holders, and full plug-n-play functionality. Forget about cutting and splicing, because all harness options in this kit will make your new low and high beam function perfectly from the original cabin controls.
Accessorize: The optional butyl-rubber glue is the most effective solution to fight back against moisture-intrusion after resealing your headlights. For the cost, it's "cheap insurance" for sure. Want to add LED Halos to accent the new projector setup? Check out new all-new XSB LED Halos and our Size Guide, so you can pick out the matching diameter for your shrouds.
Trusted: With the Internet's best reputation for unbeatable products, prices, and customer service; The Retrofit Source is trusted by car guys world-wide, so we invite you to Contact Us today with your questions. Whether you need a recommendation on parts, have a tech question, or even a wholesale inquiry: our customer service team is here to help!
[More]
What's Included
• 2x Projectors:
Morimoto Mini H1 6.0 Bi-xenon
2x Ballasts:
Morimoto XB35 AMP
2x Bulbs:
Morimoto XB H1
2x Shrouds:
User Preference
1x Wire Harness:
Morimoto Relay
Misc:
TRS Decal & Bi-xenon Emblems
Warranty:
Five Years
Shipping:
Free Ground within USA
Compatibility
• Projectors:
Low and High Beam Capable
Wire Harness:
Match your original bulb size
Vehicles:
Universal Fit (may require modification)
Installation & Performance
o Time to install:
o 4 hours (estimate)
o Cutting involved:
o Application Dependent
 photo bi-xenon_morimoto_mini_h1_stage_iii_retrofit_kit_1_zps8yze2aaw.jpg" media="(max-width: 640px)">  photo bi-xenon_morimoto_mini_h1_stage_iii_retrofit_kit_1_zps8yze2aaw.jpg" media="(max-width: 960px)">  photo bi-xenon_morimoto_mini_h1_stage_iii_retrofit_kit_1_zps8yze2aaw.jpg" media="(max-width: 1920px)">
 photo bi-xenon_morimoto_mini_h1_stage_iii_retrofit_kit_2_zpsswj7qd46.jpg" media="(max-width: 640px)">  photo bi-xenon_morimoto_mini_h1_stage_iii_retrofit_kit_2_zpsswj7qd46.jpg" media="(max-width: 960px)">  photo bi-xenon_morimoto_mini_h1_stage_iii_retrofit_kit_2_zpsswj7qd46.jpg" media="(max-width: 1920px)">
 photo bi-xenon_morimoto_mini_h1_stage_iii_retrofit_kit_13_zps5bp5oghi.jpg" media="(max-width: 640px)">  photo bi-xenon_morimoto_mini_h1_stage_iii_retrofit_kit_13_zps5bp5oghi.jpg" media="(max-width: 960px)">  photo bi-xenon_morimoto_mini_h1_stage_iii_retrofit_kit_13_zps5bp5oghi.jpg" media="(max-width: 1920px)">
 photo bi-xenon_morimoto_mini_h1_stage_iii_retrofit_kit_4_zpsxo3jw1qv.jpg" media="(max-width: 640px)">  photo bi-xenon_morimoto_mini_h1_stage_iii_retrofit_kit_4_zpsxo3jw1qv.jpg" media="(max-width: 960px)">  photo bi-xenon_morimoto_mini_h1_stage_iii_retrofit_kit_4_zpsxo3jw1qv.jpg" media="(max-width: 1920px)">
 photo Mini20H120Stage20III20Kit-1860l_zps1cb51368.jpg" media="(max-width: 640px)">  photo Mini20H120Stage20III20Kit-1860l_zps1cb51368.jpg" media="(max-width: 960px)">  photo Mini20H120Stage20III20Kit-1860l_zps1cb51368.jpg" media="(max-width: 1920px)">
1 - 1 of 1 Posts
