1 - 4 of 4 Posts
I have a 07 I bought with the 2.0 it's wrecked bit has a good engine I also have a 04 2.0 can I swap the motor from the 07 to the 04 without a problem?
2006 ZX3, 2005 ZX5
the 04 had the 2.3 duratec and the 2.0zetec. the only thing you have to do is get the wiring harness and change that from my understanding.
Old Phart
As mentioned, if the '04 has a 2.0 it is the zetec version and to swap to the later 2.0 duratec nearly the whole car needs to be swapped - saving only the shell.
To use parts from the '07 only, even the full dashboard needs to be changed, as wiring & instrument cluster change and the instrument cluster doesn't fit the earlier dash.
1 - 4 of 4 Posts
