1 - 2 of 2 Posts
I was looking for new brake pads, rotors, and lines for my 06' zx4 st, and was needing to know if the heat here in texas would screw them up?
Best bet IMO would be to get the steel braided brake lines, as they hold the best pressure under heat. The brakes and rotors should be fine unless you work them hard and then hit water, which could warp them. Other wise you should be fine.
[8]
1 - 2 of 2 Posts
