1 - 2 of 2 Posts
Not sure if this belongs in this section, but it seems to fit here the best. This is the type of antenna that is on the roof of the car just behind the windshield. Over the years of car washes, the antenna is starting to come apart.
I would be happy with a direct replacement, but I do have a head unit with HD Radio so the better the antenna I can get that will fit and look good the best.
Thanks for any suggestions!
Not sure what your asking but here's some info. Your hd radio tuner is just a digital tuner. if you're ever on the road and an analog station comes into play then the antenna on top of your car will pick that up and if it turns out to be a hd radio station then it wil switch to the built in tuner. So i would say if anything dont just remove the antenna, get an aftermarket one that looks better like you said so if an analog station ever does come along you have the ability to listen to it.
1 - 2 of 2 Posts
