1 - 3 of 3 Posts
Went to change spark plugs in the Focus and found lots of oil in the spark plug "tubes" Plug on far passenger's side was completely covered in oil... All plugs came put soaked in oil and I can see oil on top of the cylinders.
Where's the leak ? Valve cover gasket ? I'll spin the motor over without plugs to help clear the oil and try getting a clean rag inside to clear out as much oil as possible.
No signs of an oil leak anywhere else...
Thx !!!
2006 ZX3 2.0, 2006 ZX5 2.0, 2004 ZX3 SVT
Use rolled up paper towels to soak up as much oil as you can BEFORE you remove the plugs. You don't want to hydro lock your engine.
1 - 3 of 3 Posts
