Hi,
I have a question regarding some starting issues.
Problem:
Since a day or two, my car won't start. Tuesday morning, I tried starting my car and as I turn the key in the ignition I hear 1 attempt to start (a click and the starter motor for about 1 second) and my car went dead. All dash lights faded and my dome light faded as well. Its almost like my battery does not have enough power to fire up my starter motor.
This is what I've tried so far:
Before assuming it is the battery and replacing it (which is the most common assumption I guess) I tried jump starting the car with my other car which worked just fine. I drove around for about 30 mins (15 km). I parked the ST back in the garage and the next morning, same thing.
This time I spent more time trying to find what the problem is. I used my multi meter and read the Voltage from the battery (cold). The reading was around 12.50 Volts. I turned the key in the ignition once and some dash lights came on. Then I turned the head lights on (it seemed like there was just enough power to do that). I had the lights on for about 1 minute and took another reading right after. Voltage went down to about 12.25 Volts and slowly went up again back to around 12.45 -12:50.
I borrowed a battery charger and charged my battery. No luck with that, car still won't start.
I do have to mention that there was a lot of white crap (the corrosion) on the + pole which I removed/cleaned for as far possible.
Last thing I tried was connecting the multi meter to the 2 poles of the battery, had my wife try to start the car and as soon as she tried I noticed the Voltage of the battery dropped to about 4-5 Volts and all the lights in the car went off again.
I tried the same with my other car and the Voltage never went below 11 Volts.
To be honest I am a little afraid of buying a new battery and then to find out that it was actually my alternator that caused my battery to have died or another electrical leak or something.
I was wondering if someone had similar issues or has any good suggestions?
thanks
Problem:
thanks
