1 - 6 of 6 Posts
I was just driving it a few day ago and the rubber grip fell off the clutch pedal thats when i realized the whole pedal is soaked with oil. What else could it be or is it the master cylinder? how much do they run for? I also checked the brake fluid and its not that low so maybe small leak?
It`s actually brake fluid. Just to make sure...runs off the same reservoir as the brakes.
EDIT: Jeezz never mind, I gotta read the whole post.... I see you checked the brake fluid. Pull the rubber cover off the end of the master cyl. If its wet. thats your leak. Not much else it could be...
Replace brake master cylinder, and clean up the spilled fluid. Er, clean up the spilled fluid first because you're going to be laying in it to replace the master cylinder. IDK what to tell you to do about the pedal. Maybe purchase some of those wrap around "race" pedal covers [dunno]
Ya hopefully this weekend ill be able to get to it. Thanks for the help!
1 - 6 of 6 Posts
