Greetings!
I have a 2005 ST, and for the last few months I've been having a bit of difficulty with it.
It began with a misfire on a cold and damp morning while going to work. The check engine light kept blinking the whole time, and when the cylinder came back the CEL went off.
A couple of days later, same thing: cylinder missing, CEl blinks but that time it stayed on after. So I went to the dealer, and had them take the code out of the computer (and a hundred bucks from my wallet). It had two codes: P0301 and P0304. So they swapped tha #1 and #4 coils (yeah, I know...) after offering to change the coil for 150$ a pop. Thanks, but no thanks... (since I can get one of those for 63$ from TeamFord).
It didn't fix anything, obviously - and after that I got my own OBDII code reader. The next time it happened, I was able to pin-point a way to make the problem happen at will. Let's say I'm exiting a highway to get onto another. Take the ramp, and when I'm about to accelerate (hard), I have somebody on my left, so I can't get on the highway just yet. Engine stays at 4500-5000 RPM for about 10-15 seconds (in 2nd or 2rd gear), and then I
floor it up to around 6,500 RPM, and that's when I find myself accelerating with a 3-cylinder Focus ST.
Every time I was able to read the codes, it always had the same two as before: P0301 and P0304. I was supposed to swap coils 3 and 4, but I forgot until it happened again last week. When I read the code, it only had a P0304 "pending" code. So I ordered a new ignition coil, and when it came in this morning, I swapped the #4 coil for the new one, and went for a ride.
Nyet komrade, still missing a cylinder while doing the exact same thing. When I came home, got the code reader out, but now I have 3 codes: P0300, P0301 and P0304.
P0300 is ransom misfire
P0301 is misfire cylinder #1
p0304 is misfire cylinder #4.
Now, I read that somehow the #1 and #4 cylinder are linked together (they fire at the same time I seem to recall??) as are #2 and #3. So I'm trying to find what could get me the misfiring? This is a coil-on-plug system, so I guess the only common component would be the engine's computer?
Has anybody experienced something similar?? I'm kinda lost right now, and I'm not sure what the next step should be in the troubleshooting of this...
Thanks for any help!!!
