I just installed my clear corners this week, and tried to go off the how to on the site and it is not accurate for the 05s. Warning: This will take about 45-90 min. depending on tools. So here is how I did it.
Tools: 7mm wrench, 13mm wrench, phillips screw driver, and some time
First take a 7mm wrench and go around the front under side of your car and remove all of the silver screws. Then unscrew the 4 black plasic screws via a phillips head screw driver.
Next Remove the silver screws with the 7mm that are in the front wheel wells.
You should now have clear access on the passenger side, and a narrow entrance on the drivers side due to the stock intake.
Remove the lamps by twisting them counter-clockwise.
Remove the bolts on the corners with a 13mm wrench. If you have a ratcheting wrench use it, it is a life saver on the drivers side!
Note: Moving the drivers side splash gaurd so it is no longer inside the front bumper may help you out, as well as jacking the car up. But I didn't need to jack the car up to do this.
