1 - 2 of 2 Posts
Aloha! I did try open my Cluster and checked all the fuses are all working properly, then suddenly check the wire from the Overlay EL out of power( both red/red orange wires). Is there a posible to wire tap? How to do it any pictuer or instruction?? So expensive to purchace a new cluster, I want to keep stock a much a posible.. thanks
Posted via FF Mobile
Discussion Starter #2
Ok finanly I figure it out, lots of trial and errors, I did check the main fuse( by engine side) and also inside the compartment located under the steering. And the main problem was two wire supporting the Overlay EL, so what I did is to tap the ground wire and it works properly with out touching the main wire from the gauges.
1 - 2 of 2 Posts
