So I've read all over about the Cooling fan resistor, and that seems to be my problem. Leaving the AC on will cool the car fine, but without A/C the car will eventually almost overheat.
I bought the cooling fan resistor from my local dealer, and located it easily, but how do you get it out? It's shrouded on all sides.
Does anyone have a good how-to on removing the whole cooling fan assembly or the resistor alone? Do I have to remove the subframe to remove the cooling fan? I got all the clips & connectors out, but there's no where to pull this fan.
On a side note, the pigtail connecting to the resistor looks very clean & undamaged. I wish I could see the resistor itself to see if that really is the problem. Right now, I'm just assuming so. I'm going to drive the car with the new resistor zip tied in place tomorrow & see if it solves the problem (too hot to add zip ties now).
Any ideas or help would be greatly appreciated. FYI - 04 SVT 84k mi, Zx5
