1 - 20 of 22 Posts
Hello all. My name David. I am a automotive painter by trade, and I just started the tear down of the the engine bay. I will be working on the car in stages starting up front.
I’ve owned this car for 6 years, most of which it sat parked for various reasons. I’ve done some repairs and some mods but nothing to involved. The biggest change so far is the power steering, more on that later tho.
I will update this post later on but for now picture time
Hood Motor vehicle Automotive design Automotive tire Vehicle
Automotive lighting Automotive tire Motor vehicle Automotive design Automotive engine gasket
Motor vehicle Light Automotive exterior Gas Auto part
Train Motor vehicle Automotive tire Wood Bumper
Vehicle Car Gear shift Speedometer Automotive design
engine is getting rebuilt for bad rings and cylinder 3 exhaust valves are leaking. At the same time I’m shaving the bay, wire tuck, abs delete and so on. I will try to update regularly but I am a family man so bare with me. Enjoy!
Discussion Starter · #6 ·
Here is a shot the work I’ve done in the back so far.
Car Vehicle registration plate Plant Vehicle Automotive tire
shaved the lock cylinder, the blue oval and the wiper. Still need to finish the molding.
Hood Automotive lighting Automotive tire Motor vehicle Automotive design
And this is hiding behind the rear bumper
Discussion Starter · #7 ·
I’ve done a little more prep work in the bay and spent some time cleaning up my work space. Need to make space to tear down the block. I’m waiting on a few parts to start on the motor mounts.
Hood Automotive tire Motor vehicle Automotive design Automotive exterior
Hood Motor vehicle Automotive tire Vehicle Automotive exterior
Motor vehicle Automotive exterior Gas Automotive tire Auto part
I will need to figure something out for a coolant overflow, any suggestions are appreciated.
2004 ZX3 SVT EE 160k miles. 2004 ZX3 SVT 189k miles
View attachment 312569 View attachment 312570
Love the build so far. If you run a mk2 radiator you can eliminate the overflow bottle completely.
Discussion Starter · #11 ·
Currently
Motor vehicle Car Hood Vehicle Automotive design
block Is empty, subframe is bare and installed along with the lower mount to locate the driveline in the bay. And I started on the driver side motor mount
Automotive tire Motor vehicle Bumper Automotive care Automotive exterior
thats it so far, covid decided to visit for Christmas so That’s awesome. My wife and I have 5 kids so it’s been really exhausting.
Discussion Starter · #12 ·
Switched gears and started working on the wiring portion of this build. My main goal is a full wire tuck and I really want to include relocating the fuse box out of sight. The first logical step is to remove the wiring and connectors for systems I don’t want and/or have anymore. No a/c, power steering, abs or cruise control
Wood Branch Art Cloud Twig
This is the harness over the top of the transmission. The green connector is for an a/c switch.
Wood Flooring Floor Hardwood Tints and shades
Cruise control is part of the main harness.
Leaf Branch Twig Wood Plant
Abs including wheel speed sensors are part of the main harness.
Automotive lighting Hood Automotive tire Motor vehicle Bumper
These two connectors are in the drivers wheel well. The brown plug is completely used by (on my car) the abs, the grey plug has most of the cruise control wiring.
Motor vehicle Automotive tire Automotive exterior Gas Automotive wheel system
For now the brown connector will be reinstalled to seal up the wiring going into the car.
Wood Branch Twig Plant Line
Removing relays, fuses and wiring from the main harness. There is one connector for the a/c clutch and one for the power steering pressure switch.
Following this - Awesome work so far. Please keep us updated!
Are you going to stick with the OEM ECU or explore anything standalone to clean up and simplify further?
Discussion Starter · #14 · (Edited)
I’ve explored the idea of a standalone but I live in Illinois and have to do emissions testing. Keeping the stock ecu will just simplify that whole process. Thanks for following.
Hope the windshield stays in with all the vibrations.
1 - 20 of 22 Posts
